ArcGIS Pro 2.5: Is there an option to get the attribute table floated as it is open?
1797
7
03-07-2020 12:19 AM
JamalNUMAN
Legendary Contributor
For example, in ArcMap, as the attribute table is open, it gets floated but not fixed in a particular place. How to have such behavior in Pro?
Jamal Numan
Tags (1)
DanPatterson_Retired
The four rules to successful GIS career
  1. right-click
  2. left-click
  3. double-click
  4. if what you are clicking on doesn't do what you want you are clicking wrong on the wrong thing
For a single table
To always float tables
  1. right-click
  2. left-click
  3. double-click
For a single table
JamalNUMAN
Migration to Pro makes our life a bit hard. However, we still keep going
This answers my question
Jamal Numan
JamalNUMAN
I’m not sure if there is an option to get the “fields” pane floating instead of being stacked by default with the attribute table,
Jamal Numan
review the 4 rules I gave you
JamalNUMAN
Thanks Dan
I need this to be fixed at the level of options for Pro so that I avoid doing it each single time. From my screenshots above, it shows that I could get the “fields” pane floated.
Jamal Numan
I always have "stack addition views on top of the last active table view" checked on so I don't have a bunch of floating around. It is so easy to click back and forth between content and field view or if needed, I can float the field view.  In any event the table needs to be opened first before you can see the field view, so it may boil down to preference versus 'bug'
JamalNUMAN
It is at the end of the day user preferences! People are not identical in how they prefer things to be
best
Jamal
Jamal Numan
