ArcGIS Mapping Toolbar Missing
2289
03-15-2023 02:37 PM
jacklevy92
I am trying to access the toolbar that is supposed to show up in the ArcGIS mapping function but the toolbar is not populating.  The toolbar accesses base maps, dropping pins, drive times, etc.  Does anyone know why this may not be populating?
Thank you,
Jack
Robert_LeClair
Esri Esteemed Contributor
I'm confused.  Are you referencing the Quick Access Toolbar or the Editing toolbar in ArcGIS Pro?  Or are you referring to the Map Tab on the Ribbon?
jacklevy92
Whichever one is supposed to populate up in the highlighted circle area after clicking "edit" in the top right corner of an ArcGIS map.  See the screen shot:
jacklevy92
It's supposed to look like this:
Robert_LeClair
Hmmm...that appears to be PowerBI Desktop by Microsoft rather than ArcGIS Pro by Esri.  You may want to post your question in the ArcGIS for Power BI Questions - Esri Community channel rather than the ArcGIS Pro channel.  I do not know PowerBI for ArcGIS unfortunately.
jacklevy92
I'll give that a try.
Thank you!
Jack
