Arcade numeric array
1269
10-29-2022 05:02 PM
RobA
Hi there,
I'm looking to create a numerical array in Arcade to be used for numerical calculations later in my function.
I have an upper threshold for example :
var threshold = 4
I simply want to create a numerical array starting from 0 and looping through to 4 to produce:
[0,1,2,3,4] saved as an accessible numerical array.
This is a simple enough concept in R (Seq function) or Python (range function), but I'm scratching my head as to how to do this simple task using Arcade.
Any help would be greatly appreciated.
jcarlson
There's nothing built-in that does this, but you could easily create your own function:
function sequence(threshold){
    var out_arr = []
    for (var n=0; n <= threshold; n++){
        Push(out_arr, n)
    return out_arr
- Josh Carlson
Kendall County GIS
RobA
That's perfect thanks Josh  😄
