Adding multiple rasters together from a geodatabase - Getting AttributeError: 'str' object has no attribute 'write'
1911
10-30-2022 09:59 AM
Labels (2)
GriogairMorrison
I have written a script for a custom tool that gets all the rasters from a geodatabase and then adds them all together.
import arcpy
from arcpy import env
from arcpy.sa import *
workspace = arcpy.GetParameter(0)
SuitabilityRaster = arcpy.GetParameterAsText(1)
rasters = arcpy.ListRasters()
for inRaster in rasters:
             SuitabilityRaster = SuitabilityRaster + inRaster
SuitabilityRaster.write(workspace + "SuitabilityScoringGrid_Raster")
When I run the tool it gives the following error:  AttributeError: 'str' object has no attribute 'write'
Would be grateful if someone could help explain this and provide a solution? The 'SuitabilityRaster' begins as a constant raster surface with the value of 0 and then 'rasters' is a list of the rasters from the geodatabase that should be sequentially added to the 'SuitabilityRaster' within the for loop.
Thanks.
DanPatterson
MVP Esteemed Contributor
do you want to 'save' the raster? or `print` it?
in either event    ... (workspace + r"\SuitabilityScoringGrid_Raster")
would be needed
... sort of retired...
Luke_Pinner
MVP Regular Contributor
You're telling arcpy to give you the parameter as text i.e. a str object when you use GetParameterAsText.
You need a Raster object.  Try using either:
#GetParameter
SuitabilityRaster = arcpy.GetParameter(1)
or
# arcpy.Raster
SuitabilityRaster = arcpy.Raster(arcpy.GetParameterAsText(1))
You'll also need to set the workspace:
arcpy.env.workspace = arcpy.GetParameter(0)
And possibly for convert inRaster to a Raster object as arcpy.ListRasters() returns strings
    # you may need to convert inRaster to a Raster object
    # as arcpy.ListRasters() returns strings
    SuitabilityRaster = SuitabilityRaster + arcpy.Raster(inRaster)
So you'll end up with something like:
workspace = arcpy.GetParameterAsText(0)
