Adding multiple rasters together from a geodatabase - Getting AttributeError: 'str' object has no attribute 'write'
1912
10-30-2022 09:59 AM
GriogairMorrison
I have written a script for a custom tool that gets all the rasters from a geodatabase and then adds them all together.
import arcpy
from arcpy import env
from arcpy.sa import *
workspace = arcpy.GetParameter(0)
SuitabilityRaster = arcpy.GetParameterAsText(1)
rasters = arcpy.ListRasters()
for inRaster in rasters:
             SuitabilityRaster = SuitabilityRaster + inRaster
SuitabilityRaster.write(workspace + "SuitabilityScoringGrid_Raster")
When I run the tool it gives the following error:  AttributeError: 'str' object has no attribute 'write'
Would be grateful if someone could help explain this and provide a solution? The 'SuitabilityRaster' begins as a constant raster surface with the value of 0 and then 'rasters' is a list of the rasters from the geodatabase that should be sequentially added to the 'SuitabilityRaster' within the for loop.
Thanks.
DanPatterson
do you want to 'save' the raster? or `print` it?
in either event    ... (workspace + r"\SuitabilityScoringGrid_Raster")
would be needed
... sort of retired...
Luke_Pinner
MVP Regular Contributor
You're telling arcpy to give you the parameter as text i.e. a str object when you use GetParameterAsText.
You need a Raster object.  Try using either:
#GetParameter
SuitabilityRaster = arcpy.GetParameter(1)
or
# arcpy.Raster
SuitabilityRaster = arcpy.Raster(arcpy.GetParameterAsText(1))
You'll also need to set the workspace:
arcpy.env.workspace = arcpy.GetParameter(0)
And possibly for convert inRaster to a Raster object as arcpy.ListRasters() returns strings
    # you may need to convert inRaster to a Raster object
    # as arcpy.ListRasters() returns strings
    SuitabilityRaster = SuitabilityRaster + arcpy.Raster(inRaster)
So you'll end up with something like:
workspace = arcpy.GetParameterAsText(0)
