Arcade expression
1393
01-16-2023 11:21 AM
MiltonVrolijk
I want to create unique asset nr using Arcade expression to display the numbers and letters from domain field and a sequence number
for example
Road_type         → CR
Location              → 01
Sublocation        → 22
CR0122-0001
CR0117-0002
CR0251-0003
JohannesLindner
Create a database sequence: Create Database Sequence (Data Management)—ArcGIS Pro | Documentation
Use this expression in the attribute rule:
// Calculation Attribute Rule for the ID field
// triggers: Insert, Update
// Exclude from application evaluation
// If there is already a value in the ID field, return that
if(!IsEmpty($feature.AssetNumber)) {
    return $feature.AssetNumber
// get all the parts for the unique id, format them correctly
var parts = [
    $feature.RoadType,
    Text($feature.Location, "00"),
    Text($feature.Sublocation, "00"),
    Text(NextSequenceValue("NameOfTheSequence"), "0000")
// concatenate and return
return Concatenate(parts, "")
Have a great day!
Johannes
JohannesLindner
var parts = [
    $feature.RoadType,
Have a great day!
Johannes
MiltonVrolijk
Thanks, Johanes
