Arcade Expression for Distance Calculation
2195
09-14-2023 01:55 AM
HarishKV
i have two layers one is High Tide Line and another one is Land Parcel. Land parcel is a polygon feature class and High tide line is a line feature class. I want to add the straight line distance at nearest vertex of the High Tide line layer to the centroid of the land parcel layer feature i am creating. I had written a Arcade Script and its not working for me. Can anyone help?. Thanks in Advance.
var landParcelLayer = FeatureSetByName($map, "Land Parcel"); // Replace with the actual name of your Land Parcel layer
var highTideLayer = FeatureSetByName($map, "High Tide Line HTL"); // Replace with the actual name of your High Tide Line layer
var attributeName = 'Dist_HTL'; // Replace with the desired attribute name
var editingFeature = $feature;
var landParcelGeometry = Geometry(editingFeature);
var closestDistance = 999999999; // Set a large initial value
for (var vertex in highTideLayer) {
    var vertexGeometry = Geometry(vertex);
    var distance = Distance(vertexGeometry, Centroid(landParcelGeometry));
    if (distance < closestDistance) {
        closestDistance = distance;
if (closestDistance < 999999999) {
    editingFeature[attributeName] = closestDistance;
    return editingFeature;
} else {
    return 'No Nearby High Tide Line Features';
HarishKV
Hi Ken,
Thanks for connecting. I had revised script and solved the issue. Modified Script as follows :
var htl_lyr = FeatureSetByName($map, 'High Tide Line');
var editingGeometry = Centroid(editingFeature);
for (var htl_feature in htl_lyr) {
    var dist = Distance(htl_feature, editingFeature, 'meter');
    if (dist < closestDistance) {
        closestDistance = dist;
var roundedDistance = Round(closestDistance, 2); // Round to 2 decimal places
roundedDistance; // This will return the rounded closest distance in meters
KenBuja
MVP Esteemed Contributor
Are you trying to calculate the value for the field 'Dist_HTL'? If so, is it a numeric field or text field?
HarishKV
Hi Ken,
