Arcade Code Review: Set polyline M-values to cumulative length of line
7644
14
03-11-2022 10:19 AM
Bud
Legendary Contributor
I have an Arcade calculation attribute rule that sets polyline M-values to the cumulative length of the line.
The script works as expected. But I'm still a novice, so I thought I'd ask: Can the script be improved?
Notes about the script:
- It works for both singlepart and multipart features.
- It densifies true curves (unavoidable, since Arcade pre-densifies true curves).
- The code below is out-of-date. I've posted an updated version in a reply...further down in this post.
//var paths = [[[0, 5, null], [10, 10, null], [30, 0, null], [50, 10, null], [60, 10, null]]];  //JS
//Only do the calculation if the geometry was changed/edited.
if (!Equals(Geometry($feature), Geometry($originalfeature))) {
    var geom = Dictionary(Text(Geometry($feature)));
    var paths = geom['paths'];
    //Alternatively, this could be done with the Arcade distance() function. I chose to do the math manually so that the script can be used elsewhere, such as VSCode (for debugging).
    function pythagoras(x1, y1, x2, y2) {
        return sqrt(pow(x2 - x1, 2) + pow(y2 - y1, 2));
    for (var path_idx in paths) {
        var oldX = paths[0][0][0], oldY = paths[0][0][1], length = 0;
        for (var point_idx in paths[path_idx]) {
            var newX = paths[path_idx][point_idx][0], newY = paths[path_idx][point_idx][1];
            length += pythagoras(oldX, oldY, newX, newY);
            paths[path_idx][point_idx][2] = length;
            oldX = newX;
            oldY = newY;
    console(paths);
    return { "result": { "geometry": Polyline(geom) } };
    //Output: [[[0,5,0],[10,10,11.180339887498949],[30,0,33.54101966249685],[50,10,55.90169943749475],[60,10,65.90169943749476]]]
(The script was adapted from this GitHub sample: Set Ms to Index.)
Thanks!
Tags (1)
JSFiddle - Test your React, Tailwind, JavaScript, CSS, HTML online with JSFiddle.
Bud
It looks like someone posted a similar script on GitHub:
Create SetMValues
https://github.com/Esri/arcade-expressions/pull/72/commits/7a6c0c824dfc3ee24252a7a6dd57556875589399
I wonder what this comment refers to:
This Arcade expression will calculates field values from intersecting point layer
Does the attribute rule actually do that? I’m a bit rusty on Arcade.
JohannesLindner
No, it doesn't. I guess they copied the rule template and forgot to delete the comment.
Have a great day!
Johannes
Bud
For future reference, when my organization moves from Pro 2.6.8 to Pro 3.x:
...copy your geoemtry(can do this by calling Dictionary(geo) on it, prior to 3.2, you need to call Dictionary(Text(geo))).
Arcade modify only Z geometry
Bud
