Arc Pro crashes when trying to import a map
1852
06-28-2021 11:46 AM
JohnGreen
I'm new to Pro.  I'm trying to import mxd files but Arc Pro Crashes.  My fellow employee at the next can import mxd's without crashing.  We are using the same Organizational license and trying to import the same maps.
DanPatterson
If your colleague can import one of your mxd's, then you may have a bad install.
Use Windows Add/Remove programs, select Remove, then Repair to see if the install can be fixed.
... sort of retired...
MichaelVolz
Try the same process as yourself on another computer to rule out a profile issue.
DanNarsavage_IDWR
Just solved this problem for us (at v2.8.3) by setting a different graphics card.
