Another Excel -> ArcGIS Pro question
1191
04-07-2023 10:23 PM
pryagmeta
Hey guys, just trying to see if anyone has any good method for getting excel sheets (xlsx) to open in Pro 3.0? I have followed all of their online steps and installed all their drivers and .net fixes but nothing seems to work. As other threads have stated, I am experiencing a super long load time w/ the xlsx pulling into Pro; it acts as if it is loading it but never does and always has to be terminated with task manager.
So far the only thing I have found that works is either exporting to a CSV in excel, or opening it up in ArcMap 10.8 and exporting to a .dbf then bringing it into pro. Is there anyone here who can successfully pull in xlsx sheets into Pro and get it to load?
DanPatterson
MVP Esteemed Contributor
Did you  follow the order in which things needed to be done?
Discussion and solution
Solved: Newest ArcGIS Pro Release - Hangs when Excel file ... - Esri Community
Reference link from there
Install the drivers to work with Microsoft Excel files—ArcGIS Pro | Documentation
... sort of retired...
curtvprice
And if you are in a hurry or something isn't working, exporting to csv and loading from there has always worked for me, easily, in all versions of Pro.
ThomasHoman
Others seem to have the driver side well in hand so I will inquire about the excel sheet itself. What always gets me is when I receive a sheet and the column names have spaces in them.
Just like esri products don't allow spaces in field names, an opened excel sheet wants to be like a table so spaces in column names will hurt.
Just a thought.
Regards,
Tom
