After deleting a feature, it does not disappear.
4446
12
07-03-2024 05:21 AM
GregoireCatineau
Hello,
under ArcGIS Pro 3.3.0 , after deleting a polygon feature, it does not disappear and stay displayed on the screen. I have to close and open ArcGIS Pro to refresh the screen...
GregoireCatineau
Now it's ok :
I had to recreate my ArcGIS Pro Project ( it was created under a previous version of ArcgGIS Pro) and it's seems to work correctly.
Thank you.
jcarlson
Can you check the layer's caching settings? Right-click and go to properties, there should be a sub-tab for caching. I often find this kind of thing happens due to the cache not being refreshed often enough.
- Josh Carlson
Kendall County GIS
GregoireCatineau
Thank you, good idea but after cleared the cache It's always the same problem, nothing change.
jcarlson
What about disabling caching entirely? Or saving, closing, and reopening the project?
- Josh Carlson
Kendall County GIS
GregoireCatineau
Yes, when I close ArcGIS PRo and reopen the projet it's ok.
jcarlson
Definitely the cache, then. I've only been able to deal with this by completely disabling caching.
- Josh Carlson
Kendall County GIS
Georgios-NektariosTselos
Hello @GregoireCatineau , i suggest  to you to first to open the attribute table, then select by attributes and then you will see the feature selected both in  the map and the  attribute table. When you delete it from the attribute table i think your problem will be solved
Best Regards
Georgios- Nektarios Tselos
GregoireCatineau
the deleting works by row selection but when I do CTRL+Z (undo) it don't work so (displaying), even if I disable the cache.
Maybe I have to install the 3.3.1 patch..
Probable you should save the new attribute table after the delete. Another solution-idea which could help you is to duplicate the feature layer and then do the  procedure!
Best Regards
RTPL_AU
Yes - I have encountered this behaviour too with lines in a FGDB. Just have not had time to fire up other computers (with older Pro versions) to double check or figure out what's going on.
I could save edits, and refresh map to have deleted items disappear.
