with ArcPro 3.1 there is the ability to enable Time on raster layers. This python modules dont have an option to input the start and end time for a raster file, it only allows you to set the field, which raster files do not have. How can I use python to enable the time property on a raster layer, and set the start and end times without having to go into ArcPro and manually set them?
I want to be able to do something like:
map.listLayers(l)[0].enableTime('Date','Date2') in python so I can batch process hundreds of raster files and add them to a project so the Time is set. This works for a shapefile that has an attribute table, because I can create a field with the start and end date and add them. But I want to be able to do this for a raster.
I would also love to see this capability for our company workflow as we're working with dozens to hundreds of historical aerial images that need to be checked for changes. Using the time-slider to do so would be a great advantage over toogling visibility and swiping hundreds of times a day!
I finally managed to enable time on raster layers by setting the layers attributes via the CIM:
import datetime
p = arcpy.mp.ArcGISProject("CURRENT")
m = p.activeMap
for l in m.listLayers():
if l.isRasterLayer:
l_cim = l.getDefinition('V3')
l_cim.useVisibilityTimeExtent = True
time_extent = arcpy.cim.CIMExternal.TimeExtent()
layer_date = datetime.datetime(YYYY, M, DD, tzinfo=datetime.timezone.utc) # replace YYYY, M, DD with the date of the raster-layer
time_extent.start = layer_date
time_extent.end = layer_date
l_cim.visibilityTimeExtent = time_extent
l.setDefinition(l_cim)
