2D layers not displaying in 3D Scene.
23168
25
07-28-2015 04:01 PM
TrippCorbin
I have created a new project using the Local Scene project template in ArcGIS Pro 1.1. My 2D layers which I added from an existing file geodatabase are not visible in the scene. They are turned on in my Contents pane and are set to ground. If I move the layers to 3D they appear. I was not having this issue with the ArcGIS 1.1 beta version I had been using.
If I add my local DEM as an elevation surface in addition to the default world elevation used by ArcGIS Pro, the 2D layers become visible. The minute I remove my local DEM, they disappear again. I have set the elevation surface to no color and allowed navigation below surface. The 2D layers will not show up.
Tags (1)
by Anonymous User
Not applicable
local. A warning would be helpful.. to protect us, from ourselves.
TrippCorbin
In my case all my data was in a defined projection. Good to know about the lack of warning if it is missing.
Dr__SamArundel
I have a very similar problem.
1. I used the local template to build a scene.
2. I added the two layers below to that scene. Those two layers are both in the same coordinate system. Besides the two layers I have added, there is the default Topographic layer. No other layers exist in the scene.
     a. a bare earth DEM created from las files as a raster in a file geodatabase (called DEM below).
     b. an index of the the las tiles (from which I built the DEM) as a polygon shapefile. (called TILES below).
I want to see my DEM in 3D, but I cannot add it to the 3D Layers group. However, in the 2D Layer group, it does draw, just flat.
I CAN add my TILES to the 3D Layers group. but I cannot pan the scene view in a 3D-way. The view only zooms in and out with my mouse wheel.
I have set my DEM as the Ground in the Map Properties>Scene>Elevation Surface properties
What I see is a very strange picture.
Can anyone help?
Thanks!
Sam
TrippCorbin
So I would try a couple things. First make sure to set your DEM as the ground elevation for your scene. Then try removing the Esri elevation surface. This will set your DEM as the ground surface elevation. That may help fix your problem.
Now I might be mistaken on this but I don't believe a raster can be a 3D layer. I think all 3D layers currently must be vector. However if you set your ground surface as your DEM then add it as a 2D layer, it should drape over the DEM Ground surface creating a 3D view. Similar to adding an aerial. DEM Sample.PNG
JeremyWright
looks like you need to:
1.  add the dem to the ground surface.  do this in Map Properties->Elevation Surface, click the "add data" button and path to your DEM.  Once it's added, make sure it's on top.
2.  Move the tiles to the 2d layers group.  You want them to "Drape" on the DEM, not be flat tiles that are passing through it.
3.  Make sure all layers are set to "on the ground" in the Elevation layer properties tab.
Dr__SamArundel
Thanks, Jeremy!
If you read all the way through my original post, you will see that I had
already completed #1.
#3 was also "done."
So I moved the TILES to 2D.
I still cannot 'explore' in 3D. Pan just pans and the mouse wheel just
zooms in and out. I cannot rotate, change my viewing angle, etc.
Sam
David
by Esri Contributor
Dr. Arundel,
To explore in 3D with the mouse wheel, press down on the wheel (click) and move the mouse around. You can also use keyboard shortcuts like:
v  + arrow keys: to rotate around center
b + arrow keys: to look around
arrow keys to nudge
press and hold q and move the mouse to roam
They only work when viewing a 3D scene and make sure you have the Explore tool chosen to take advantage of these keyboard shortcuts.
JeremyWright
PROTIP: If you're using another tool such as measure, an editing tool, or selection, etc. you can always hold down the C key to get back the Explore tool temporarily.
Dr. Arundel,
If you switch back to Explore tool or use the C hotkey, does that let you move in 3d?
Dr__SamArundel
​Thanks, so that's part of the problem. The 3D nav tools don't work. I know
how to move around in 3D, I have done it before, just not on my currently
installed version of Pro. When I press my mouse wheel down, and scroll, it
only zooms in. There appears to be something either wrong with my ​project
(which to test, I have created a new project, with the same problem), or my
install, or the software itself.
Dr__SamArundel
Yes, so pressing down on the wheel and moving the mouse zooms in and out
only.
The keyboard shortcuts do the same thing.
