Export Raster (to JPG) — Limit compression quality to 0-100%
575
10-16-2024 04:22 PM
Status: Closed
Bud
Esteemed Contributor
ArcGIS Pro 3.3.2; File Geodatabase raster
Contents Pane > Data > Export Raster
Output Format: JPG
The Compression Quality parameter can be set to a value above 100%, such as 116%.
The tooltip says the values can only be from 0 to 100. But that contradicts the actual values available in the parameter.
Idea: Limit the Compression Quality values to 0-100%, disallowing values above 100.
2 Comments
Bud
Esri Casee 03748798 ArcGIS Pro 3.3.2 - Export Raster - JPG compression quality above 100%
BUG-000171586: Compression Quality when using Export Raster does not honor the range from 0 to 100
KoryKramer
Status changed to: Closed
