ArcGIS Pro 3.3.2; File Geodatabase raster
Contents Pane > Data > Export Raster
Output Format: JPG
The Compression Quality parameter can be set to a value above 100%, such as 116%.
The tooltip says the values can only be from 0 to 100. But that contradicts the actual values available in the parameter.
Idea: Limit the Compression Quality values to 0-100%, disallowing values above 100.
Closing this as it is not an idea. The bug is here: https://support.esri.com/en-us/bug/the-compression-quality-setting-in-the-export-raster-pa-bug-00017...
