Expand docked attribute table width in ArcGIS Pro
3899
09-13-2017 10:17 AM
Status: Open
deleted-user-sYHsW3p_gN5o
In Pro, if I have the Contents pane docked on the left and any other pane docked on the right, my attribute table sits at the bottom in between the two. Why can't I choose to have it cover the entire bottom of the screen? I only need the contents pane to be so tall, so I'd like to be able to see more attribute columns instead.
attribute_table  docking‌ panes‌ attributes pane‌ attributetable‌ arcgispro‌ arcgis pro tables‌
5 Comments
KoryKramer
The idea is valid, but I just wanted to share that if you hide panes on the side, you'll get the entire screen width for your attribute table:
Thanks for the response Kory. That is useful in some circumstances, but often i do need to also see the Table of Contents and/or the Geoprocessing/Catalog/other pane.
KoryKramer
In response to https://community.esri.com/ideas/14052-arcgis-pro-remember-attribute-table-location, in ArcGIS Pro 2.5 it will be possible to approximate the request here with the exception that the table won't be docked.
For example,
lah
is this still not possible? Looking for better attribute table placement, similar to ArcMap.
CarmenBollman_Geo
I agree... if you can dock the other panes (Contents, Catalog, Error Inspector) across the entire bottom, you should be able to dock any pane the same way...
