Would love to be able to produce elevation profiles better...
- Multi-Surface Display (with options for filling in between surfaces)
- add vertical exaggeration scale and scale definition options
- add to layout as editiable graphics, rather than rasterized image (or, even better, provide option to add as shapefiles within a seperate data frame with XY and Z coordinates "flipped" along the profile line - i.e. X coordinate would be distance along line, Y coordinate would be equivalent to Z, with some sort of option to apply vertical exaggeration while producing)
- provide options to display other 3D features alongside the surface profile (within X distance (i.e. underground utilities, boreholes, etc.)
Ultimately this type of tool would work in ArcMap, allowing display of profiles next to traditional map frames...
it's similar to this https://community.esri.com/ideas/4782.
a lot of peole need this.
we also need:
- export to dwg/dxf
- adding more than one dataset, also flat-data like a landuse or parcel shapefile
- it should work dynamically and fast like in arcmap but also with a set of cross sections in a fc/shapefile
Hi all,
There are a number of ideas on this page, which is great. I wanted to see if you'd had a chance to try the new interactive Elevation Profile tool in ArcGIS Pro, to see if some of your workflows can be met.
Quick summary of requests:
Screenshot of profile graph display options (per #6)
I hope this helps get you started on evaluating the interactive profile graph in Pro!
Thanks, Nathan.
@NathanShephard thank you for posting this. However, I cannot find this tool. The only tool available from the Exploratory 3D Analyst menu is "Object Detection". Just updated ArcGIS Pro today (personal use license).
Referring to this page
Any help would be appreciated
