Even in ArcGIS 10.1 version, I don't see the ability to populate the database domain's codes and descriptions of a feature class's field meta data automatically. It is possible to edit metadata and add domain code and description one by one. Instead manually doing, is there a way to get/import/populate domain code and description automatically into metadata of the feature class? I did not find any auto population possibility unless export domains in to a table and edit an exported xml file and importing it back.
I wish if there is a way to get domains auto populated as it is a heavy time consuming task to do manually, if there are many feature classes and many domains to maintain good metadata.
Hope ESRI experts will address this in future. Thank You.
As Collector for ArcGIS is becoming more popular with my organization, attribute domain lists are becoming more popular and longer. We are also finding ourselves updating our attribute domains more frequently. If ESRI could make the metadata information formulate from and update with attribute domains, it would be much easier to convince my co-workers that completing their metadata is worth their time.
