Definition Query in Attribute Table
2550
09-09-2011 07:41 AM
Status: Open
JurajKrumpolec
Indicate active Definition Query in Attribute Table and provide easy controls for DQ creation and modification.
0EM30000000CrgV
  • Display number of queried records vs. total (without DQ applied)
  • Switch between queried/all records display
  • Indicate fields used in Query Expression (Excel like Attribute Table formatting and control)
  • Definition Query Expression Text Box directly in Attribute Table
  • Interactive Visual Query Builder – create query expression simply by selecting the desired attribute values directly in Attribute Table (Intelligent Query Expression Builder)
4 Comments
MarieDucharme2
If I may add to the list:
  • Allow to toggle the definition query on and off (as opposed to having to delete the query)
  • In the TOC, have an indicator for layer that have a defition query applied (perhaps have the layer name in italics, or underlined, or have an asterix at the end)....anything that would help determine if a layer has a defintion quiery on it or not w/out having to go all the way into the layer properties definition query tab.
wayfaringrob
Related idea for Pro: Definition Query - Esri Community
Bud
JChristoff
Can we get a couple simple buttons added to the top of attribute tables that will give us quick access to definition query options? One to open the DQ property window of the current layer and On/Off buttons for each saved query. We could easily save a few clicks and some window space!
