Catalog Expand to Open Folder
3302
23
01-05-2021 01:47 PM
Status: Implemented
Meg_Southee_WCS
New Contributor II
In ArcPro, add the ability to expand to the open folder in the Contents Pane when you click on an item in the Catalog View.  This functionality exists in ArcGIS Catalog and in Microsoft File Explorer.  Adding this feature to ArcPro would help with content management, and navigating the data structure.
23 Comments
NaicongLi
Hi @AndrewWillingale,
Thank you very much for catching this!  I have corrected my comment above.
SamPalmer
@NaicongLi Doesn't seem to be working for me. I am using Pro 3.2. I think I have enabled correct settings:
project > options > catalog view > expand to current location.
I have also started a new project.
Any ideas?
NaicongLi
@SamPalmer Please make sure that you did check "Expand to current location" in the Options dialog box, as in the screenshot in my earlier comment, repeated here:
By the way, if "Add a folder connection for locations not in the project" is also checked under "Location bar" above, then the path you pasted in the Catalog view Location bar would automatically be added as a folder connection in your project, and the folder expansion would happen under the Folders project container instead of under This PC.
