Allow dynamic pictures in report group footers
3092
07-15-2021 09:30 AM
Status: Implemented
tempStephenRhea_NV5
Dynamic pictures can only be added to the Details section of a report, which means I can't take advantage of the Reporting functionality in Pro. I have an ArcMap workflow that runs LOS analyses on multiple Viewer Points to check the visibility of multiple Site Points. After the analyses are run, I generate a report that divides each page by Viewer Point and includes an image of the map showing the results of just that Viewer Point. The report is HTML rendered into a WinForms WebBrowser control so users can print to PDF (the client tends to frown on third-party libraries). I would love to use Pro's reporting engine to save the users the additional step and avoid the workaround, but right now I can't because of the dynamic picture restriction.
The attached image shows how I want to divide the report pieces in the designer. The Group Header and Details sections translate fine, but I can't add a dynamic image to the Group Footer.
4 Comments
LindsayMiller1
Additionally, I'd like to ensure this includes the ability to add multiple dynamic images to the same report. Thank you!
AlyciaRajendran_esri
Hello!
This functionality will be available at Pro 2.9 (this fall).
Thanks!
- Alycia
KoryKramer
KoryKramer
This is implemented in ArcGIS Pro 2.9.  See Ideas in ArcGIS Pro 2.9
