When creating a parcel via the traverse tool, how do I restart the traverse tool to make adjustments?
1752
03-28-2024 12:15 PM
VogtBoat
When creating parcels with the traverse tool, sometimes I think I am done, I save and close out the traverse tool, but then I realize I need to add or adjust the traverses. How do I restart the traverse tool on my lines and then adjust the measurements of the previously created lines?
2 Solutions
MDB_GIS
Unless there is a way I am unaware of, I think once you have finalized a traverse and closed that window, you won't be able to get it back. You can "Export an ArcMap Traverse" file using the hamburger menu in the Traverse tool to save a copy of your traverse before you close it, and then import it again. Once it is gone, however, I don't think you can bring it back up.
ChristineLeslie
Yes you can restart/resume a traverse by tracing in the lines into the traverse grid. Trace in the lines, make your edits and the lines will reflect the edits.
https://pro.arcgis.com/en/pro-app/latest/help/editing/create-a-traverse.htm#ESRI_SECTION1_08880D70C6...
However if you have built a parcel, you will need to do Reconstruct From Seeds first...
https://pro.arcgis.com/en/pro-app/latest/help/data/parcel-editing/reconstructfromseeds.htm
Christine
MDB_GIS
VogtBoat
Bummer! Thanks @MDB_GIS for the workaround.
ChristineLeslie
Christine
