Is there a way to easily select Points within the Parcel Fabric that are not covered by lines?
My current understanding of the requirement: select points that are not used by any connections lines, not used by any parcel type lines, and not used by any historic parcel type lines. Depending on the subsequent action, control points may also need to be excluded from the resulting set.
When I first tried this on Friday I found this is not as easy to do in a map with multiple parcel types. In working on this again today, I found the following approach worked:
This could also be automated via python scripting.
I have not seen an integrated tool to do this.
I usually use select by location and go through each line type to find points that don't fall on a line.
It would be nice to see something built in!
@LebowskiThis is a good candidate for the Parcel Fabric Ideas board
Thanks, Tim
Hi Chad,
There is a very simple way - use Select By Location.
I have used the parcel polygons layer because it is smaller and the "Boundary Touches" method.
It took 6 seconds on a layer with 43K parcels
It selected the correct points:
Is this easy enough?
Amir and Tim,
Thank you very much for your response!
The reason we need to identify uncovered ‘Points’ is that throughout our migration process many of our parcels have lost coincidence, causing misalignment between parcels and creating unwanted ‘Points’. I have also noticed that many of our PLSS lines are not true two-point lines, which is also creating unwanted ‘Points’.
In response, I created a ‘Task’ that will help to rectify the issues above. It recreates the PLSS lines, making sure they are true two-point lines and are coincident. At the end of the process, I am looking for an intuitive method to identify ‘Points’ that are no longer covered by lines and need to be deleted so they do not cause misalignments moving forward.
