Importing Symbology and retaining Seeds
879
05-05-2023 07:07 AM
chamberlin_d
We are currently very close to transitioning from map fabric, to pro.  I am wanting to provide a mapx file for some custom tools we are creating.  When dumping a new fabric into the map, we see that each polygon feature in its respective bucket shows a 'Parcel' and a 'Seed'.  We are looking to differentiate each type of parcel that we have, i.e. lot, outlot, park, etc.  The ability to import symbology exists in Pro, and we have layer files from our map fabric.
When importing, we lose the logic that symbolizes seeds.  When we add logic for the seeds back in, we lose our imported symbology.  Would anyone want to share if they are using our same setup, and what expression you are using?
Attached is bringing in our layer file with the seeds missing.
chamberlin_d
I did notice that if there is no logic set in place to have different symbology for a seed, it will keep the same defined colors/pattern in the seed circle.  So this answers my question in that you can remove the logic that is built in for the seed, creating seeds will result in the use of the defined polygons.
