Closed traverse in ArcGIS pro 2.3?
1375
05-28-2019 06:31 AM
vincezubia
#cogo
Where do I learn how to run metes and bounds to get a closed travers in Arc GIS pro?
How do I enter curve data while building the closed traverse?
Thanks
Vince
Tags (3)
by Anonymous User
Not applicable
Hi Vince,
Here's the documentation on COGO: https://pro.arcgis.com/en/pro-app/help/editing/create-a-traverse.htm
And specifically for closed traverses: https://pro.arcgis.com/en/pro-app/help/editing/create-a-traverse.htm#ESRI_SECTION1_A709CA338B9847D68...
Hopefully, that gets you started, but if you have specific questions, let us know!
-Lauren
vincezubia
Hi Lauren,
Excellent information you sent on cogo. As soon as I get a chance I’ll start learning all new commands in Arc pro for closed traverse.
I was so comfortable using cogo in Arc map, now to relearn everything again.
Thanks
Vince Zubia
GIS/Plat & Subdivision Specialist II
El Paso Central Appraisal District
5801 Trowbridge Rd.
El Paso TX. 79925
(915) 780-2012
FAX: (915) 780-2010
vinzubia@epcad.org<mailto:vinzubia@epcad.org>
[cid:image002.jpg@01D5153D.2A50E2B0]
