I'm running ArcGIS Pro 2.8.2. I created a new project and in that project I created a new Parcel Fabric. When I add that fabric to a map in the project, the "List by editing" tab has warning icons saying there is a later version of the fabric available and I should use the Upgrade Dataset tool to update it. I try to do that and it says I'm using the latest version.
Anyone else experiencing that?
Solved! Go to Solution.
Hi Jeff,
Yes, this is a defect and has been corrected at ArcGIS Pro 2.9. Apologies for any inconvenience.
Dan
yeah, it's a bug i ran into as well. it won't actually stop you from editing or anything.
Jeff,
My fabric layers also show the warning icon and tell me that I am not running the latest version. I am on 2.8.2 and running version 4. The Upgrade Dataset tool tells me that I am already on the latest version.
I also see this warning when running the Validate Parcel Fabric geoprocessing tool.
It has been like this for as long as I can remember. I have just ignored it since it doesn't seem to be causing any issues.
-Paul
I am running into the same thing AND I can't edit it. Are you able to edit?
Hi Jeff,
Dan
