ArcGIS Parcel Fabric Blog
Other Boards in This Place
Latest Activity
(21 Posts)
KenGalliher1
Released with Pro 3.2 is the ability to read and update the active parcel record in a map containing a parcel fabric.
Read more...
more
5 0 215
AmirBar-Maor
My first reaction was: "Why would anyone want to downgrade?"
Read more...
more
8 0 592
AmirBar-Maor
This is a sample that might be useful for some as reference.
Using 11 lines of Python to create and load polygons from a shape file to a new parcel fabric.
This is something that could not be done in ArcMap and can have useful use cases such as digital submission.
You can copy paste it to the python view (command line) after you tweak your source data or wrap it up as a python script tool.
ParcelSourceData= r"C:\Temp\Parcels.SHP" #source polygons
SR=arcpy.Describe(ParcelSourceData).spatialReference #retrieve the spatial reference of source data
FGDB=arcpy.CreateFileGDB_management(r"C:/temp", "fGDB.gdb") #create a file geodatabase
FDS=arcpy.CreateFeatureDataset_management(FGDB,"FDS", SR)  #Create a feature dataset using the spatial reference
PF = arcpy.CreateParcelFabric_parcel(FDS,"ParcelFabric")   #Creating a new parcel fabric
(PF,Parcels,Lines) = arcpy.AddParcelType_parcel(PF, "Ownership")  #adding a parcel type
arcpy.AddField_management(Parcels,"RecordName", 'TEXT')    #Adding a field for the record name that is used for records creation
arcpy.management.Append(ParcelSourceData, Parcels, "NO_TEST")  #appending source data to parcel polygons
arcpy.EnableParcelTopology_parcel(PF)                      #enable parcel fabric topology
arcpy.CreateParcelRecords_parcel(Parcels, "RecordName")    #creating new parcel records
arcpy.BuildParcelFabric_parcel(PF)                         #building the parcel fabric
#ParcelFabric#ArcGISPro24#arcpy.parcels
more
2 3 1,040
218 Subscribers
Labels
