'Zoom to' not working properly in pop-ups
889
05-30-2024 09:36 AM
SimonCrutchley
Hi folks,
I've built apps in the past using Map Classic (MC) and WebApp Builder (WAB), but I'm now looking to replicate in Map Viewer (MV) and Experience Builder (EB). There is a built-in element in the pop-up in MV (and indeed Classic), which is ‘Zoom to’. In MC it does what it says on the tin and zooms to the selected feature, but in MV it just zooms in ‘a bit’. Is there any way to control this zoom setting, as it doesn’t appear in the code in the pop-up edit.
This is the WAB app where the 'zoom to' from the top level hexagons works - https://historicengland.maps.arcgis.com/apps/webappviewer/index.html?id=2626ed0c37484d96b8954dd33187...
and here's the EB app where it doesn't
https://experience.arcgis.com/experience/038cfbbe3edf43efb7d0330eb913f38e/?draft=true
Incidentally, the layer visibility for the photo density layers doesn't work either; it appears fine in the app editor, but when you launch it, both the 25km and 100km layers are visible.
Any help with either of these issues would be gratefully received.
Ta
Laura
by MVP Regular Contributor
