Operations Dashboard not honoring refresh interval set in web map after Nov 2024 update
1379
11-13-2024 12:47 PM
WetherbeeDorshow
After the November update, refresh intervals set on hosted feature service layers in the web map are not working in operations dashboards
WetherbeeDorshow
@skisantafe_admin
Stephanie_F
Hi @WetherbeeDorshow do you have more information about this?
What refresh interval do you have set?
Are there specific widgets you are seeing this behavior with in your Dashboards?
If possible an Esri Technical Support case would be great to investigate deeper. https://support.esri.com/en-us/contact
SkiSantaFeAdmin
The refresh interval is set to 0.1 for everything and none of it is updating. Lists and details widgets.
Stephanie_F
Thanks @SkiSantaFeAdmin Can  you confirm what layer type you are using to reproduce that? I had initially tested with a hosted feature service at .5 and confirmed that was working as expected but hosted feature services have a lower limit of .5 for the refresh interval.
