YouTube iFrame tag no longer working in Map Viewer Classic WebMap popup
793
7
07-06-2021 11:42 AM
WillHussung
Hello all.  I noticed late last week that the html code I use to embed Youtube video links in a popup window in the Map Viewer Classic Webmap is no longer working.  Instead of loading the YouTube video in the popup it now only displays the code that is populated in the field.  Did anything change recently that would break the iFrame tag in a popup.
Code example:
<iframe width="100%" height="160" src="https://www.youtube.com/embed/6lB1Mq2Vxzo" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
PaulinaMarczak1
New Contributor II
similar issue with Canada Weather Alerts in Map Viewer Classic URL : https://geo.weather.gc.ca/geomet-beta?lang=en&service=WMS&request=GetCapabilities. Popup is showing <iframe>.. </iframe> instead of actual data
JosephCarl2
New Contributor III
Ah I am having the same issue! glad it is not just me.
Henry
Occasional Contributor II
I'm having a similar issue with some iframes for interactive panoramas. It just displays the iframe code and doesn't load the iframe itself. I know that these can be loaded into iframes but for some reason I'm just getting the code.
Henry
JosephCarl2
New Contributor III
Any updates on this? The technical article was removed.
WillemVan_Riet1
New Contributor II
also wondering if this has been resolved?
ThorstenHohenstrater
New Contributor III
any suggestions by Esri Tech team?
Thorsten Hohenstrater
Amanda__Huber
This is affecting our organization as well. Can someone from Esri please provide us with an update or workaround?
Thank you,
Amanda Huber
