Why can't I add my shapefiles from file even though they're under 1000 points?
9721
33
10-26-2017 02:10 AM
SimonCrutchley
I have two shapes files, both with less than 1000 features, (one c4MB, the other 1.3MB). When I try to add them to my map from file I get an error saying they're too large. I can add them as shapefiles in Content, but then can't create feature classes to add them to the map.
Help.
Thanks
DanPatterson_Retired
SimonCrutchley
Hi Dan,
I've replied to the linked thread, but am replying direct to you too. The problem is that, as you can see, I don't appear to have the Publish to Feature Layer check box. Any idea why that might be?
XanderBakker
Esri Esteemed Contributor
Could you attach the ZIP file to the thread? That way we can see if this is related to your account or the data.
And what coordinate system is the shapefile in?
SimonCrutchley
XanderBakker
It is not the data, since it allows me to publish the ZIP you shared (sorry for the Spanish interface):
and it draws correctly:
Do you have a Level 2 Named  User? Are there any restrictions on publishing content in the role assigned to your named user?
Simon... first confirm your privileges to publish which is 2 step
add items  http://doc.arcgis.com/en/arcgis-online/share-maps/add-items.htm
share items  http://doc.arcgis.com/en/arcgis-online/share-maps/share-items.htm
and to make sure you have all the bits http://doc.arcgis.com/en/arcgis-online/reference/shapefiles.htm and have all the necessary steps.
Including the publish features http://doc.arcgis.com/en/arcgis-online/share-maps/publish-features.htm which comes back to privileges again
SimonCrutchley
Hi Dan,
I'm just a private user and can't see any Role in my profile. Since it's just my account I can't think why I'd have any restrictions on loading my data.
XanderBakker
Can you contact the portal administrator to see if the role configured for your account allows you to publish data to the portal?
SimonCrutchley
How do I do that? Who is the portal administrator?
Sorry to be clueless.
