Which Files To Upload in ArcGIS Online Map
1386
05-12-2020 11:19 AM
RobinDiSalvo1
I just received seven different file types to upload in AGOL but am not sure if I need to upload all or just one?  The file types are: CPG, DBF, PRJ, SBN, SBX, SHP SHX along with a XML document.  Can anyone please guide me to where I can learn more about how to upload these type of files on a map?
Any help you can provide would be much appreciated - this is for a huge project.
Thanks in advance,
Robin
Katie_Clark
Hi Robin,
This page should answer your question!
Shapefiles—ArcGIS Online Help | Documentation
Specifically:
The primary way to make shapefile data available for others to view through a web browser is to add it to a .zip file, upload it, and publish a hosted feature layer. The .zip file must contain at least the .shp, .shx, .dbf, and .prj files components of the shapefile.
Hope that helps!
-Katherine
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
