Where to report an issue with bad map information?
1192
09-26-2022 12:54 PM
GaryBrimley
I've been looking around and honestly just don't have more time to dedicate to this search. It results in two questions: My initial question, and now a general question borne out of my failed effort to find a solution.
1. Where can I report an issue of bad map data in numerous base maps? In the base maps {"Charted Territory Map," "Colored Pencil Map," "Light Gray Canvas," "National Geographic," "Outline Map," and "Terrain with Labels"} at lat/long 40.71072 -110.95842 Lovenia Lake is depicted much larger than it actually is, and quite at odds with the topography contours surrounding its southern and eastern edges. When was the last time you saw a lake with a series of 800 feet of contours going right through it?
2. Can the method to report such an issue be improved?
Also I'm new to the community and I couldn't determine any fitting category for this post. I don't know if I or someone can recategorize it if it fits better somewhere else.
George_Thompson
Esri Notable Contributor
George_Thompson
There is an ArcGIS Online group: https://www.arcgis.com/home/group.html?id=e796c4f5b27b431a804184fc51d10b40#overview
That you can add the correct service and provide feedback. https://support.esri.com/en/technical-article/000011831
--- George T.
GaryBrimley
