Webapp builder print widget asking for sign in
2163
11
11-14-2022 06:52 AM
Oliver_Burdekin
Occasional Contributor II
I've added the print widget to a webapp builder app. In the past this worked fine but recently I've been getting a pop up asking for sign in credentials the first time I use the widget. This will peridoically return. If I cancel the request I'm still able to print the map to pdf without any problems. Here's what the login box looks like:
All the layers, maps etc are within the same group with the same sharing policies, none of whihc have been changed recently.
Has anyone else experienced and how can I make the sign in pop up go away?
Cheers,
Oliver
iHack
I am having the same issue with the Print Widget in Web AppBuilder on Portal 10.8.1; but, instead of the login box, it takes me to our Portal login page. Hoping to find a solution soon.
Joel_Lopez
I am also having this exact same issue. Were you able to find a solution?
