Hello - as of the June update, it appears that vector style point symbols are not drawing completely 'stacked', where at least one style point is offset from the rest:
This is a Sewer Vault from the UN symbology published as a hosted feature layer to arcgisonline. At publish time from Pro 3.1.2, the symbology option 'use symbol types with all clients' is un-checked. Up until the update, this offset did not appear in Map Viewer.
Solved! Go to Solution.
thanks we can see the regression in the API and looking at fixing this with a patch.
Can you share the web map and/or layer for this?
Thanks!
Russ
Sure @RussRoberts - its part of a feature layer collection. I'll set it public temporarily and I will DM it to you. If you could let me know when you interact with it that would be great
Or I can add you to a group in our org if you reply here or DM me your agol user name . . .
add whatever you can to a group and invite russell_jsapi to the group and I can take a look.
ok Russ here you go:
Its the SewerManholeVault sublayer . . .
Can you share that layer to the group again. We have a fix in to go out with a patch and want to verify against your layer.
This was fixed in a patch last night.
Russ
Sorry @RussRoberts - buried Thursday and Friday. Yes, I can verify this is fixed, the vector point style symbol is no longer off-setting . . . thanks for your help
