Vector Style Point Symbols offsetting in Map Viewer
3210
9
06-21-2023 06:01 AM
DavidColey
MVP Frequent Contributor
Hello - as of the June update, it appears that vector style point symbols are not drawing completely 'stacked', where at least one style point is offset from the rest:
This is a Sewer Vault from the UN symbology published as a hosted feature layer to arcgisonline.  At publish time from Pro 3.1.2, the symbology option 'use symbol types with all clients' is un-checked.  Up until the update, this offset did not appear in Map Viewer.
RussRoberts
Esri Notable Contributor
thanks we can see the regression in the API and looking at fixing this with a patch.
RussRoberts
Can you share the web map and/or layer for this?
Thanks!
Russ
DavidColey
Sure @RussRoberts  - its part of a feature layer collection.  I'll set it public temporarily and I will DM it to you.  If you could let me know when you interact with it that would be great
DavidColey
Or I can add you to a group in our org if you reply here or DM me your agol user name . . .
RussRoberts
add whatever you can to a group and invite russell_jsapi to the group and I can take a look.
DavidColey
RussRoberts
RussRoberts
Can you share that layer to the group again. We have a fix in to go out with a patch and want to verify against your layer.
RussRoberts
This was fixed in a patch last night.
Russ
DavidColey
Sorry @RussRoberts - buried Thursday and Friday.  Yes, I can verify this is fixed, the vector point style symbol is no longer off-setting . . . thanks for your help
