Use hex codes in if/else statement using Arcade
3552
06-10-2021 11:13 AM
Hannah_Hutchins
I have a custom pop-up where I'm using HTML and Arcade expressions to communicate whether or not a Library was included in an event. I have a large table built in the pop-up using HTML (see "HTML.txt") and inside that table, I have Arcade expressions using if/else statements to return an "X" if the result is true (or the Library was involved). I'm using a "1" in the attribute table indicating that a Library was involved and a "0" if they were not involved.
Here is an example of one arcade expression (titled: {expression/expr0}) which I then bring into the table HTML code (I have one arcade expression for each Library - probably not efficient, but I'm new to arcade!):
var X = $feature["Augsburg_Park"];
IIf (X == 1, 'X', '');
This results in a pop-up that looks like this:
Here is where I need help!
If a Library has an "X" in the table next to it (meaning it was included in an event), I would like to have the text (Library name and the "X") bolded and change colors (#00AEEF).
How do I integrate hex codes and font changes into an arcade expression?
MarkBockenhauer
MarkBockenhauer
SarahRijneke
Can this be achieved in ArcPro?
edward33
This way listed above will not work. If you wish to do it in ArcPro follow this:
For hex values: #eb4034
For rgb values: rgb(123,45,67)
Example expression using hex with when statements and Arcade:
