Updating a layer in ArcGIS Online using Excel
3426
06-29-2015 03:18 AM
WendiPedersen
Hello everyone,
Is it possible to link an excel table with a data layer on ArcGIS Online and have the data layer be updated as the excel is updated? I have two Excel tables, both are copies of the attribute tables from two separate data layers I am working with. These two excels will be updated continuously, ideally it would be great to have the layer in ArcGIS Online and excel connected to make it easier to have these updates reflected in the data layer. One layer will only need a text column updated which will adjust symbology in the map, while the other will need to allow for new locations to be added to the data set.  Is this possible, if so how would I do this?
Thank you so much for all your help!
Best,
Wendi
