Update of field values for features
933
07-09-2023 04:40 PM
MaikHeinze
Hey,
Is there a way to update selected attributes? When updating, all fields of the selected features should be updated.
A bulk update would also be fine. The main thing is that the fields get updated.
King regards
Maik
LindsayRaabe_FPCWA
MVP Regular Contributor
Can you provide more information? Based on the assumption that you are working in the ArcGIS Online Map Viewer, have the layer table open and have selected records that way - the short answer would be no.
There is no calculate attribute option that can be applied to records in Map Viewer. You would need to either use the Update data option through the layer item details page, or alternatively, through ArcGIS Pro.
Lindsay Raabe
GIS Officer
Forest Products Commission WA
MaikHeinze
Thank you for the prompt response. I work with ArcGIS Pro.
I have attribute rules that transfer values to features. I want to select these features and, if possible, update the fields in the feature with a button click.
