Update Data Not Finding My 'assettype' Field?
470
04-16-2025 12:07 PM
Labels (2)
ShelbyMyers
I'm trying to update a feature layer within an ESRI solution with the relevant features that I currently have on a locally saved layer, but when I get to the page where you match the fields, it keeps saying my 'assettype' field doesn't exist, and since null values aren't allowed for this field I can't continue updating the data.
The shapefile I'm trying to append to the hosted layer is in the same schema, the 'assettype' field is there and has no null values, so I don't understand why ArcGIS Online isn't finding it. I've tried multiple times, even going so far as opening the destination layer in desktop to append the data there, to then export that as a shp to update the data Online, but it still doesn't find the 'assettype' field. I inserted two screenshots, the first being the fields view for the source layer (this is the same as the destination schema), and then how the field isn't showing when I try adding this data as a shp. Any suggestions?
