I am experiencing an issue loading base maps in ArcGIS Online. However, I am experiencing this issue in ArcMap, QGIS, and an app I use on two of my android devices called "Canada Topo Maps" as well.
In short, when I am connected to wifi, any Esri base maps won't load in any of the above mentioned products. Usually the result is just a blank white layout. ArcGIS Online map viewer is the only product that produces an error, with everything else, the map just simply does not load.
Another interesting detail. When I use my topo maps app on my android devices with data instead of wifi, the base maps load no problem.
The message I get in ArcGIS Online is as follows:
I am not a part of an organization, I am using a free AGOL account.
Any thoughts?
Issue resolved. My IP had been blocked.
