Hello - Since the October update I am no longer able to edit existing custom member roles:
For Settings>Member Roles>Manage Roles I now only see this when I attempt to edit the role:
I am not able to get at any of the settings to view or adjust privileges, etc.
Anyone else?
Thanks!
Thanks @RussRoberts - this seems to have resolved itself for the time being - after a Desktop restart to install Windows updates and a Chrome update. Cache was cleared multiple times prior. Behavior is now normal. I will start looking at the existing network traffic as soon as I can.
I should add when I try to set privileges from an existing role, the dropdown does not populate with any of the default roles:
Just remains blank
I couldn't reproduce this issue with my org. Are you able to look at the network traffic when you open up that Import from existing and see if the /sharing/rest/portals/self/roles query comes back with results? Also have you cleared your cache to see if that has resolved anything? cc @JacobLias1
