Time needed to Publishing from arcgis pro to arcgis online
2988
12-28-2023 04:34 PM
maherelayyan2
Hi
what is the Time needed to Publishing from arcgis pro to arcgis online since i am trying to publish
a feature layer in arcgis pro with 6500 records and it is working 24 hrs and still give working in progess
is this normal ?
Thanks
bbollin
Hi @maherelayyan2 that is an unusually long time for publishing. It should take a few minutes maximum depending on your network connectivity. I strongly recommend you contact Esri support to work through this issue https://support.esri.com/en-us/contact
bbollin
maherelayyan2
Thanks for reply finally it was published after more than 24 hrs
