Symbols in the hosted feature layer are no showing in Map Viewer Style
245
04-26-2024 08:24 AM
Cepero_Eudel
New Contributor III
I have a layer with traffic signs. I noted some missing symbols and updated it  in my ArcGIS project, then overwrite my hosted feature layer in AGOL to update these symbols as well. The symbols  updated properly in the hosted feature layer but no on the Web Map (map viewer).
Note, I did the overwrite by checking "Use symbols types compatible with all clients in Pro before publishing".
Any help will be really appreciated.
RussRoberts
Esri Notable Contributor
The symbols could have been downgraded when you checked on Use symbols types compatible with all clients in Pro before publishing" or the layer item or web map has a symbol being used vs. what exists at the service level. I would have to check out the map/layer to verify this.
Cepero_Eudel
New Contributor III
Thank you for your prompt response.
I will make the map layer public and share.
By the way, this happens only when overwrite no when publishing a new hosted feature.
