Symbology of voxel layer in ArcGIS Online
3389
17
03-23-2022 02:02 AM
MatthewLau
Hi all,
I published a voxel layer to ArcGIS Online, but the color scheme doesn't not match. For example, the dark green should be shown as red. I've gone through the layer property in ArcGIS Online. It seems that there is no option for me to change the color scheme. May I know if there any way to solve this problem? Any comment is welcome. Thank you!
Matthew
MatthewLau
OK, I put my SLPK file here.
RussRoberts
Esri Notable Contributor
Thanks! If you can share the raw data as well that would be helpful. I am seeing the difference between the SL online and the SLPK on pro.
MatthewLau
Do you mean the original voxel file in ".nc" format? Sure, I can provide if you need.
RussRoberts
Yup if you dont want to post it here you can dm me the file.
MatthewLau
Sure, then I drop my file here fyr.
RussRoberts
got it thanks!
MatthewLau
It seems that this problem is difficult to solve... and I still have no clue...
RussRoberts
This issue will be resolved with Pro 3.0 update. Here is SV left and Pro Right with a voxel SLPK generated in Pro 3.0
