Symbology Disappears when Adding/Editing Feature in Map Viewer Classic
2585
02-09-2023 05:44 AM
StormwaterAdmin
I have a web map that we use in Map Viewer Classic. I have the layers symbolized by unique attribute. Usually when a user goes to the Edit tab to add a new feature, they can see the different symbols for the layer and choose one to add to the map. Now it only shows one symbol in the Add Features pane as well as in the map. I would like to fix this so we can see the different symbols/types for each layer. The layers with this issue were all published from Portal.
Any help would be greatly appreciated!
RussRoberts
Esri Notable Contributor
Without the map & service my guess would be bc the service does not have these types & templates present that would be used to populate this panel
StormwaterAdmin
Ok, that makes sense. Any ideas how to fix that? Should I republish the service from Portal?
IanTeh
Hi, I have the same experience and I can't find a solution to it as well.
