Splitting data in an attribute table into multiple fields
10622
12
06-08-2021 01:37 AM
SimonCrutchley
I have data in a concatenated list, created so that it is searchable in a single attribute, but I now discover that I need to make hyperlinks to the various entries
The easiest way to do this seems to be to split them into separate entries and then do a link to each unique entry, as there are far too many different combinations.
I currently have the concatenated fields separated by / e.g. the field currently called 'TYPE' has entries such as 'ENCLOSURE/FIELD/FIELD SYSTEM/SETTLEMENT' and I would like this to become a number of separate new fields TYPE1 = 'ENCLOSURE', TYPE2 = 'FIELD', TYPE3 = 'FIELD SYSTEM' etc
I attach a sample of a file where I did the split manually, to see if the process would produce the data in a form that I could then use in Portal, in a pop-up.
Hope you can help
Thanks
I suspect this may be similar to the solution given to another post I had Splitting data in an attribute table
SimonCrutchley
I've just realised that some entries don't have multiples, so there is no '\'. Is this the problem? If so, do I need to filter on multiples, or is there a way to do this in the script?
Thanks
JayantaPoddar
You can use this modified script for others (except Type1). The split function uses the same logic as before, i.e. [1] for Type2 and [2] for Type3.
If (Find('\\',$feature.NARROWTYPE, 0) > 0)
Split($feature.NARROWTYPE,'\\')[1]
else
Think Location
SimonCrutchley
Thanks for that, but I'm now very puzzled, as checking 'Verify' it seems to be valid
but on actually running it, I get an error?
How is that even possible?
Sorry
