Spatial Analysis result Layers not Searchable
602
04-24-2013 11:32 AM
EamonnDoyle
Hi
I have used the new Spatial Analysis (beta) tools to produce a new Layer using the Summarize Data> Aggregate Points function. This works perfectly well and produced a new Item in My Content as expected. The new Item is Tagged with reasonable Tags. I can search for the Item from the My Content page without a problem. However when I use Add > Search for Layers in the Map page the Item can not be found or is not returned by the Search even when a valid Tag is used.
Eamonn
MikeMinami
Esri Notable Contributor
I am not seeing this behavior. I can do a tag search on a recently created layer from analysis. Can you provide a set of steps to reproduce the problem?
Mike
