serial chart in dashboard
715
11-17-2025 09:43 AM
ErinHoover
Hello! I am new at doing dashboard for ArcGIS Online. I tried to create a serial chart, and it looks weird. I am trying to get the serial chart to look like the one in Excel. Does anyone have a tip on how to get it to look like this and what is the correct type for data field for hosted feature for year and linear ft? Thanks in advance!
CodyPatterson
MVP Regular Contributor
Hey @ErinHoover
If you're mentioning x and y labeled charts then you may have some luck with this post here:
https://community.esri.com/t5/arcgis-online-questions/creating-a-serial-chart-in-dashboard-using-arc...
You can definitely get this pretty close to what you're looking for, here's the docs: https://doc.arcgis.com/en/dashboards/latest/get-started/serial-chart.htm
Cody
ErinHoover
Hi! Thanks for your feedback. I was wondering if you know why Total Length ft shows only string instead of giving option for either double or float?
CodyPatterson
Hey @ErinHoover
Are you uploading it from Excel as a drop in? If so, ArcGIS Online typically takes the value from the first entry in the Excel to declare the data type. In some cases you may need to create a layer with your desired format, and then append the Excel information to it, here's a post about it as well:
https://community.esri.com/t5/arcgis-online-questions/hosted-table-field-only-uploading-as-a-string-...
Cody
ErinHoover
Disregard..I was able to figure out!
