Routing Network Dataset, Error opening Network Dataset -- Access Denied
4982
07-18-2013 11:23 AM
HunterStone
When I try to load the FGDB Routing Network Dataset from StreetMap Premium (2013 Release 1), I continue to receive the the following error: Error opening Network Dataset: Access Denied.
I am running ArcGIS for Desktop 10.1 SP1.
Any help is greatly appreciated!
RobertPfingsten
I am getting the same with 2013 R2.  Did you get your issue resolved and how did you resolve your issue?
AzinSharaf
Occasional Contributor II
I have the same issue with releas3 2013. any idea?
AzinSharaf
Solved. you need the correct license file.
NareshBanoth
How do I check it whether I have correct license file or not?
